If your TX does not support dual elevator servos you can look into a Smart Fly Equalizer. This little device will plug into your elevator channel, and then you plug your elevator servos into it. The device allows you to reverse either one of the servos, adjust their center and end points independently so you can match up the elevator travels perfectly. Something you just can't get with a reversing Y.
