There's no reason it shouldn't bind with an imported model. Did you check the Frame Rate screen? Was it set for DSMX and 11ms?
Were you too close? What were the symptoms that lead to it not binding?
Did you bind with the button, or from the menu? With complicated models it's often better to bind from the menu so that things like the sequencers are in the correct positions.
Andy
