Originally Posted by
abufletcher
I've never had a model with a servo for each elevator half (in the tail). So how do I do the radio setup for this? In my hazy thinking I imagined I could just connect the two with a Y-harness and then a long lead to the Rx. But the Y-harness reverses one servo. Or is there some other type of Y-harness needed? Or is the additional elevator servo also connected to the Rx, and if so how?
I'm using an 8-ch Airtronics RDS8000.
The Y harness does not reverse the servo. You just have to make sure that you put the horn on the right side of the servo. I have at least 3 large scale models with dual elevator servos on a Y. IT mainly depends on how much capability you have with your radio and RX ports. It can be nice to mix them electronically.
