Originally Posted by
smkrcflyer
I start with a small block plane then finish with the sander. The block plane really cuts down on the sanding time.
I used block planes at times but had better results with using like 40 or 60 grit sanding paper and progressively finer grit as I got closer to the final shape. Planes and I sometimes don't get along with each other. On larger surfaces I found that the removal of material goes more uniform with the 12" or larger sanding bars. It's up to the individual user and what they are most comfortable with using. I like the sanding bars with the stick on sand paper. Gotten better results with I thought greater control. I setup a jig at the edge of my building table that holds the surface in place. It allows an angled approach to remove the surface material. Worked great and I didn't remove too much. Though it does create a lot of dust. But that is why one has the Shop Vac.
