RCU Forums - View Single Post - Dual elevator servos?
Old 01-04-2015 | 02:11 PM
  #53
vertical grimmace's Avatar
vertical grimmace
So they don't need to be reversed. Put the pushrod on the opposite side.
Then, if you mix through the radio, and you can't swap the servo horn to the other side (which we do not know this from not seeing the application) you give one servo -100% and the other +100%.
I am of the opinion that you do not add additional items unless absolutely necessary. More expense and failure points.
