RCU Forums - View Single Post - What the hell did I get myself into?
Old 01-05-2015 | 02:46 AM
  #41
Rapid13
Things have been moving along much faster than I thought. Most everything has been going together well. When I glued the fuse bottom on I glued the masking tape to the fuse. PITA but I got it sanded off. Probably should have used medium CA instead of thin. Then the wing bolt plate and former F3 had a gap in it that I filled with a shaved down piece of balsa. Other than that I have some small gaps but I guess that is to be expected. I will probably fill them with the filler I use for the control tubes. Now I need to get an engine. I want to go OS but am not sure if I should get the .46LA or spend the extra money and get the .46AX. Since this is my first plane I'm kinda leaning towards the LA to save money.
ID:	2061010   Click image for larger version
ID:	2061011   Click image for larger version
ID:	2061012   Click image for larger version
