RCU Forums - View Single Post - Dual elevator servos?
Old 01-05-2015 | 05:50 AM
  #66
abufletcher's Avatar
abufletcher
#@%@! Two unpleasant discoveries: 1) I'm getting some twitching on the servos at rest and 2) while I was under the wing I found that on the right aileron three of the seven hinges hadn't slipped into their slots while doing the epoxying. If we number them 1, 2, 3, 4, 5, 6, 7 starting inboard, then hinges 1, 2, and 4 aren't attached to the wing (only to the aileron). I don't know how I allowed this to happen. I was so cautious otherwise, even went to the effort to put dabs of grease around the actually hinge area to prevent epoxy from getting in there. It probably looked fine from the other side and I didn't check it. #@%@#. Not sure what to do about that. Cut off all the other hinges? Drill out the old hinge bits? Start all over?
Also don't know what to think or do about the twitching.
