RCU Forums - View Single Post - High Torque motors on HL Leopard 2 problem
Old 01-05-2015 | 01:44 PM
heavyaslead's Avatar
heavyaslead
Originally Posted by YHR
I have found Lipo's are the battery to use in situations like this. The issue is more the battery then the ESC. If you use a lipo this issue will stop or fry your ESC if the motors are truly drawing that much amperage.
IN all the cases where I had tanks shutting down from to much amp draw( Brownout) the Lipo cured it every time, and to date all my RX18's are still fine.
Also what gauge wire are you using to supply the ESC from the battery.
That's interesting Dan, but makes me wonder how the RC car guys get high output on their batteries without brown-out, I mean they were using NiCad's and NiMH batts for years before Lipo's and us tankers came on the scene.
It's probably a combination of Battery current drain, ESC max surge and motor stall characteristics.
I'm sure a hot motor can be used if the stall current is low for his application.
