RCU Forums - View Single Post - 90 size Kaos
Thread: 90 size Kaos
Old 01-05-2015 | 03:15 PM
RDJeff
Default 90 size Kaos
Hi gang! I'll be starting on a 90 size Kaos soon, and am looking for any advice or tips or criticism that the learned people here can provide. This will be built from the Eureka short kit, with a foam wing. I've built a number of kits over the years, but never a foam wing, so this will be exciting! I'll be powering it with an OS .91 FX with a Davis Diesel conversion head. Probably will run a 16 x 8 prop to start with. I'll be using Spring Air retracts on it, also a first for me. The plan is to use pull/pull rudder control, and some form of solid rods for the elevators, or I might put the elevator servos in the rear, we'll see. I also have a rotary drive setup that is just waiting to be used for the ailerons.
