The SBC-1 Channel-Setting Tool only allows you to set the channel used by an S-bus servo or an S-Bus decoder. It is really not a servo programmer. You can do more if you program from the transmitter, and really do a lot if you program from a PC, using the CIU-2 and the PC-Link or S-Link software, depending upon which servo you're programming.
