RCU Forums - View Single Post - High Torque motors on HL Leopard 2 problem
Old 01-06-2015 | 08:43 AM
heavyaslead's Avatar
heavyaslead
Originally Posted by nexusys
Hi All,
Sent an email to the seller, i get this back from them:
"Hi
This item has been used in many heng long tanks without any problem. I suspect your 4700 mah battery has caused the problem. It is recommended to use with heng long 1700mah battery.
You can send it back for refund if you do not like it, per our return policy
Regards"
Failed to answer my question. Looks to me an easy way out for the seller. And of course arrogant. Didn't expect that at all.
Yep, i just watched them, (was at work yesterday, so no go for youtube videos). That looks good, just what i was expecting to have. I got all the speed, but not when spinning, and climbing.....
This is the problem, i couldnt obtain this information from the seller.. see above response from them...
This is what im considering.. an ESC that can handle this... any suggestion?
That will be an experiment.... good suggestion, but i think we all drawn to mainboard is the culprit..... maybe...
Hey YHR, can you confirm this? i would consider to get LIPO instead...
I dont use any other wire apart from stock supplied stuff...
Hey Kizwan, this is it... no brand or whatsover..
Thanks all for keep the topic rolling....!
I use the same gearboxes in my T55 tank with stock motors with no problems (and Tamiya electronics), so I suspect it goes back to the motors having a really high stall current.
