Dad didn't like the tight clamp I located the servo wire with so we changed to a clamp with a larger hole to prevent the wire from work hardening. Small Robart air tank fitted for chute system. I didn't have the SM tanks but a bit of fuel line took care of the fit. Hot glue to fix them in place. Nose gear doors hooked up. I'm gonna sequence with a button valve.
