Originally Posted by
osvaldopv
I'm thinking to move from my Jr 12x to a Jeti system, can someone tell me how easy is the Jeti compare with the 12x regarding the programing and mixes.
I did just that coming from a long history of JR 10X 10S and 12X (which in my view was not as good). There is a learning curve for sure like changing OS system all together you have to unlearn or forget your old ways and relearn a new way of thinking.
No aileron to elevator or aileron to rudder preset for example, but that is the beauty of the system you do what you want with it and it will do it.
I had to send my 12X to the shop to get the proper ailerons snafu corrected in the programming, being in Canada that was an ordeal. With Jeti all upgrades are computer based and free (with the -16 at least)
Once you get your mind into the Jeti way, everything seems so easy and much more ''that is the way it should be''.
Easier not at first, but no limitations in anything you want and can think of.
