Opening the box you find the fuselage with canopy and semi-reproducing copkit, the two wings (Up & Down), the tailplane in one piece and the rudder, in addition to the two wing supports which connect the lower the top wings. To mount the Quantum takes 15 minutes and you do not need to use glue. All parts are locked in place with the screws provided in the kit. The assemblu started fixing the quote after passing the servo pins in the fuselage and block into place. It then proceeds with the fixing the rudder and then switch to fixing two wings: before the bottom wing with use the plastic support wings (attention that have a side up and side down...) and the upper one that locks in the fuselage with two screws. All already assembled I'ts solid and secure.
