RCU Forums - View Single Post - BJ Craft Passion
Old 01-10-2015 | 02:08 PM
  #47
flyintexan's Avatar
flyintexan
Jer,
yes, there is a good amount of right thrust in the nose. I actually ended up adding a touch more as well. I also have a 1.5mm shim under the te of the bottom wing and under the le of the top wing. The shims seem to be common among passion owners in the far East. My cg is about 115mm back from le on the bottom wing. I'm not sure the shims would be needed if running a more aft cg. I am really pleased with how it tracks and Flys.
good luck,
Mark
