Well Unfortunately the X10+ is mounted inside the wing where you can't see it.
On this Ultra-Flash I have electric gear and brakes. I was going for something that was very quick to assemble.
I used a 14 pin Molex Connector. I am using the X-10+ to provide the PWM signal to the Rt Aileron, Lt Aileron, Rt Flap and Lt Flap.
For Power I doubled up on the pins. 2 for + and 2 for - . I also used two pins for the S.Bus2 Signal wire for redundancy. Then I have my Right Gear, Left Gear, Right Brake and Left Brake. 2 pins each.
Hope that helps.
