RCU Forums - View Single Post - Glues for kits?
Thread: Glues for kits?
Old 01-15-2015 | 01:41 PM
SushiHunter's Avatar
SushiHunter
Originally Posted by Pylonracr
I use the same glue Bob does, with one exception. I use laminating resin to glue tail components to the fuselage when I need some time to align the part. CA glue is a one shot deal and sometimes I need a minute to set the alignment.
Yeah, same in regards to the CA and one shot deal issue with me as well. I know guys who will build an entire plane with CA and I don't know how they can do it, since when I build, I have to make minor adjustments after everything has been put into place and the glue applied. They must probably get everything in perfect place and use the most fluid type of CA and it just soaks in, I don't know. In regards to Gorilla glue, not sure how many different types there are, but I know guys who've accidently glued stuff shut because it swells up/expands when it completely cures, compared to how it was when it was first applied. So be sure to take that into consideration when using Gorilla glue in tight places where there are moving / movable parts and control surfaces.
