The features
Even this Quantum is marketed in PNP version, ready to fly, and only needs the connection to the receiver to be flying. It has a 'wingspan of less than 1109mm and 1267mm top of a fuselage length of 1389mm for total wing area of 46.6 D㎡. The motorization is Edf 90mm to 11 blades that equips both the Viper that the Valkyrie and that combined with a brushless motor Motor: BL3541 KV1450 provides lipo 6 with a thrust more than enough for a good flight. The controller is installed as standard with a 80ampere and separate UBEC 8A which supplies both Rx and gear. The servos are installed is 9 in total all 9 grams digital with metal gears; complete kit electric gear retract very good with metal legs always sprung metal and sequencer to the front door.
