The assembly
Opening the box yo found in the package the entire fuselage with canopy and semi reproducing copkit, the two wings, the tailplane in one piece and the vertical, in addition to the two wing supports which connect the lower flange to the top. To mount the Quantum takes 15 minutes and you do not need to use glue. All parts are locked in place with the screws provided in the kit. It starts from the helm horizontally after passing the cable pins of the moving parts in the fuselage locks into place. It then proceeds with the vertical and then move to the wings: before the dow wing and ixed the pilon plastic wings (attention beocouse the fixing wing pylons have a precise sense of attachmentthat and you need to check that the holr correspond to the length of the pilon base up and down); after you can fixed the up wing and locks in the fuselage with two screws. All this assembled are safe for flying.
fte you can goes to make the connections of the lead pins of the servo. The lower wings have a link multicontact which is inserted in the appropriate green base in the fuselage (as shown) and in the servo plug female you simply attach the spinet male who find in the up wing: the servo ailerons are connec a single channel and are "replicated" in the green based in fusoage; the sae solution is apply for front wheel and rudder: this will enable if you use a 6 channelsRx; if you wish to use separate channels for the up and down aileron will need to modify the wiring of the leads (very simple but you must d it before assembly the two wings). I've left everything as standard.
