RE: Wing sheeting required?
Thank you all for guiding me regarding sheeting. I will be making a relatively slow flyer, not speed devils sort. I will be using two main spars, le and te spars all these spars will be very strong I will also use more spars between main spar and le spar. I will also use Sheer web. I think it will do the job strong and sheeting will not be required ?
Thanks for guiding once again and any further information is welcome and thanks in advance
vikas
