Originally Posted by
wfield0455
David, I like your brake pulse implementation. Thinking about it further, if you are using a ds16 sequencer to control your gear and doors, couldn't you simply add the brakes and give a pulse before raising the gear and have the sequencer only pulse as the gear is being raised?. The gear and door sequences would be symmetrical.. I don't have my ds16 handy so I haven't tried it yet though. Can you think of any reason it wouldn't work?
Wayne..... if you use the sequencer to pulse your brakes the sequencer channel will take control (over ride) over the actual switch (or lever) controlling your brakes..
David..
