thanks guy's. It's all monokote covered I first laid it out like i was going to paint it with masking tape( the cheap masking tape for this) and then applied the white up to the tape lines. Then i applied the "wine" colored monokote up to where the white left off. Then the purple was applied like a stripe at low heat and when i had it all laid down went over the entire airframe with a heat gun rubbing it down as i went. The wing well i had to apply the wine and purple and silver stripes at low heat over the white and then go over with a heat gun once it was in place. I will also attach a pic of the bottom. No real secrets to the covering just stretch and pull and use proper heat. I love monokote. Phil
