Does anyone have a copy of the CB Elektronics JJXC (NON EX Version) ECU Protocol converter instructions? I've lost my instruction sheet and the data sheet on line has no operating instructions. I'm moving the unit to another plane with an older ECU that operates on a 2S Lipo pack and I need the proper switch settings to set it to Alarm at the proper voltage. The rotary switch is currently set to position "A" which I assume is correct for a 3S A123, ECU pack so I need the correct switch position for a 2S Lipo ECU pack. Any help would be appreciated. I still have the CD that came with the unit which I assumed contained the instructions but it contains nothing but a few Empty folders and no files of any kind which seems kind of strange.
