Originally Posted by
dbacque
I wouldn't say that counterweighting is always the answer. If any part of the linkage isn't stiff, that's where I always start.
Counterweights will always cure flutter....you could even disconnect the surface from the linkage and it won't flutter. But its also true that lighter surfaces and stiffer linkages do help prevent and control flutter.
