Wayne there are 5 inputs/outputs on the cortex and each can be used to stabilize any surface
so you can have two Seperate elevator input to the the cortex and then to separate elevators allowing you to reverse one as needed in the Tx. Then when you do the learning phase of the setup the gyro learns your radio setup.
