RCU Forums - View Single Post - Flutter - How to find the cause??
Old 01-19-2015 | 04:14 PM
  #69
vertical grimmace's Avatar
vertical grimmace
This is a good example of information overload! This Tauri model is not a 3D model, with gynormous surfaces. It also has no leading edge control surface exposed to the airstream. So adding ballast may we be a solution, but I am telling you, if you clip those ailerons back, it will most likely stop.
