Originally Posted by
hitman5363
How did I come up with the 5 inch number. Easy, since the wings insert partially into the fuselage it is really easy to measure from where the leading edge will be in the inserted area and back from there to the center of the carbon fiber wing rod is exactly 5 inches.
Many many times I have used the manufacturers CG measurement and then once out in the field flying I did not like the performance of the model so I went back to my old method of balancing on the wing rod.....(using a string with a loop in each end that is put over the wing rod).... and moving forward from there to find the perfect spot.
Not scientific at all....basically just balancing the model
Similar method to a Vanessa cg rig but not quite.
I posted a link somewhere here if you're interested.
