RCU Forums - View Single Post - Demon Cortex Gyro question
Old 01-20-2015 | 03:47 PM
  #332
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by siclick33
You don't even need to do that with the latest software. You can simply select the appropriate channel off in the appropriate bank, using the 'channels assigned' option in the Bank 1 and Bank 2 pages. Doing it this way allows you to retain stabilisation for the rudder when the gear is up.
Other than saying to set the gain to 0 for the nose wheel steering channel in one of the banks instead of uncheck it (I wasn't in front of the computer and I did this over a month ago), isn't that exactly what I said? The bottom line is 2 banks, both normal mode, 1 bank has stabilization turned of on the NSW channel the other doesn't. Both banks have everything else enabled, Doesn't that about sum it up or am I missing something else?
