You can't set the gain for individual channels, only the gain for the axis (i.e. elevator, aileron and rudder). If you set the 'rudder' gain to zero to remove the stabilisation to the steering (you can't set NWS gain to zero on its own) then you lose stabilisation to the rudder as well, which isn't what you want. However, you can turn individual channels off using the toggle option in the software.
Originally Posted by
wfield0455
Other than saying to set the gain to 0 for the nose wheel steering channel in one of the banks instead of uncheck it (I wasn't in front of the computer and I did this over a month ago), isn't that exactly what I said? The bottom line is 2 banks, both normal mode, 1 bank has stabilization turned of on the NSW channel the other doesn't. Both banks have everything else enabled, Doesn't that about sum it up or am I missing something else?
