Been thinking on servo setup and the existing servo tray. I am using one of the sleeves for the rudder for my single elevator push rod.
This is the best location for the elevator. This gives a nice relative strait shot to the linkage and servo.
I am going with the solid 1/4" aluminum rod over the brass tube. I will tap a 2/56 pin threw the arm and then two threaded bolts into the elevator halves.
The two elevator sleeves will be the pull-pull for the rudder.
So fare I will have two or three servos depending if I do a separate servo for stering, may just do rudder and stering on the same servo.
Next time when I get back to it I will join the elevators. Then work on the rudder.
TB
