RE: help on covering
pt-power- In a pinch, you can use a clothes iron. The larger size makes it a little more difficult to use, but if you take your time and follow the instructions that come with the covering, you can get very good results. Watch the temperature of the iron and don't allow it to touch open areas. When heat shrink covering first came out, there were no special irons or heat guns so using your wife's iron was the only option. Jim
