Actually there are quite a few two stroke engines that use unpinned rings. One has to be careful as you can run across engines with a pinned piston/ring that might mess up your day, if you weren't paying attention. If I remember correctly, they put a very tiny slight taper on the ring ends and that keeps them from getting into a open port. Also they may use more webs in the ports too.
