RCU Forums - View Single Post - Top Flite GS P-47 sports scale; diary of a build
Thread
01-25-2015, 10:07 AM
1644
TonyBuilder
My Feedback: (
11
1 Post
The lower hinge pick is done. Some 1/32" birch ply and easy sand did the trick.
I could not resist the scale rudder linkage.........so.
I thought I would try the scale linkage for the rudder while I was here.....why not!
So I fleped the arm around, moved the ball inks in to the closets hole, and cut the excess off.
This looks like it will work and as the rudder doesn't have much throw on it anyways the pull-pull should be fined
So far everything clears and there is no conflict with the elevator arm. I can attach some cables and see how it will perform. I may add one more hinge pint in this area to stiffing the lower half up.
I will make a cover plate to cover the cut out in the rudder like I did on the prototype.
TB
Reply
Like
TonyBuilder
View Public Profile
Send a private message to TonyBuilder
Find More Posts by TonyBuilder
View iTrader Profile
