Originally Posted by
phmaximus
Is it the cheapest??....
Yes it is because you do not need any tools or equipment at all if it really came down to it. For example, you could count a hundred salmon lengths (if you had a salmon (sarcasm alert)) and count the time to travel the distance, from that you can calculate how fast it is travelling in salmons/hour! :P If you know how long the salmon is then you can convert the salmons/hr to something more familiar.
Being more realistic- you do not need to measure the distance in total, if you only have a 5m measure then lay it end to end a number of times.....or just use your plates of meat (feet).
