RCU Forums - View Single Post - Remove spring on Walbro carb?
Old 10-12-2003 | 04:29 PM
Antique's Avatar
Antique
Default RE: Remove spring on Walbro carb?
The answer is no...Unless it's put together wrong the throttle shaft has a clip or washer on the end opposite the lever that connects to the throttle servo....The spring goes under the lever and keeps the shaft against the clip..If the disc is not centered when the clip is against the carb body it should be loosened up and re centered...The spring will then keep it on the middle....[8D]
