RCU Forums - View Single Post - MT 35cc fuel problem?
Old 01-28-2015 | 02:32 PM
michael wood's Avatar
michael wood
that would cause an air leak. is the gasket glue you are using fuel proof if not you might need a new back plate. and you don't need to screw the carb bolt down to tight just snug remember its plastic you are screwing into you can seal the back plate up with high temp (red) gasket sealer
