Originally Posted by
chuck l
I'm looking for sanding sealer to use on balsa and went shopping for some this afternoon. The only one I could find was Minwax sanding sealer which appears to be waterbased which would totally defeat the purpose of using a sealer on balsa. What are you guys using? Deft is impossible to find.
Chuck
What are you looking to use it for?
If you're looking for Fuel Proof stuff, you can still get this,,,
http://www3.towerhobbies.com/cgi-bin...&I=LXAU64&P=ML
To find real Lacquer based SS, you'll want to call around the Mom n Pop Paint stores, down side, you'll probably only get in in gallon sizes, the big Box stores don't carry it often
good luck
