Joe,
Do you know the exact location where the engine will be mounted and where the exhaust will be split into the two engine outlets.
In otherwords, I imagine the engine will be well forward of the HS pivot rods, but the twin exhaust tubs must be going right through these pivot rods
Do you need to build fiberglass exhaust tubes through inlet and outlet areas to keep the air as laminar as possible?
