RCU Forums - View Single Post - Looking for a trainer, what's available. (Updated 8-20-2011)
Old 02-01-2015 | 03:14 PM
joebahl's Avatar
joebahl
Nice flights but try flying over where you want to land but higher in the air then set up your ladings with 90 degree turns slow lazy ones till you can turn 90 degrees and be set up to where you need to be.. Its hard to judge where your at by looking up and trying to look at the field at the same time so getting use to 90 degree turns will help you line your landings up without loosing sight of your plane by looking down . BTW i see its a tri gear but what does the rest of the plane look like ? Congrats on the nice flights Craig ! joe
