From Gerry:
( As an aside, could you respond to the 2 questions from the previous installment? Specifically, the rudder servo will be on top of the wing and easily connected at assembly by a Dubro
spring actuated ball "clevis". As for the cowling, that beautifully spun aluminum A6M5 cowling that came with the Royal kit is all wrong. I'll be scratch building the Rufe cowling from
blue foam, fiberglass and resin, using the lost foam technique. )
