RCU Forums - View Single Post - quad 75 ?
Thread: quad 75 ?
Old 02-03-2015 | 09:10 AM
larry@coyotenet
My Feedback: (21)
Double check the carb, sounds like the internal needle is stuck or bad. Check the arm that lifts the needle, some just rest on the button on the diaphragm, some need to be hooked into the grooves on the button. I have seen both on walbro carbs. If yours needs to be hooked and you did not hook it, it will flood like crazy.
Larry
