Robart air system
As I am new to air retracts thought I would ask this simple question before I tear the system apart to locate an air leak.
I have aTop Flite B-25 that I purchased on line. However I have taken most of the components apart and started reassembling it to insure it meets "my specs". So upon pressurizing the system to 100lbs the system holds the pressure for about 2 hrs or less. Is that normal or is something leaking? Is it normal to have to pressurize the system after each flight?
Rafeek
