I was balancing mine on the aft CG since it helped with balance, your pipe is probably smaller than mine so that deff helped you not use as much nose weight. I may install a smoke system down the road, if so this will eliminate the need for nose weight with an extra battery in the nose. Thanks for the info
Originally Posted by
In the Haze
Not sure about overall weight, I added 450 grams to get CG 320mm from leading edge.. K210 with smoke and vector nozzle.
Will test fly this weekend.
