+1 to what serious power said. Move your linkages in at the servo arm and/or out at the control surface to reduce the amount of throw. The end point adjustment should be used for minor adjustments as it will be difficult to get exactly 15mm by adjusting the linkages alone. The larger your endpoint and dual rate settings remain, the smoother and more precise your sticks will be.
