Assembly in progress. Balsa blocks are on the underside of the top piece. They provide reinforcement and will also provide form for when I round the corners after assembly.
Where clamps don't fit, weight often works!
The weight is to hold the top and its attached block to the freshly glued port side piece. Looks like it's doing a fine job. The block on the right is there temporarily to level the stack of weight.
Getting there.
