[QUOTE=AndyKunz;11979890]Correction: Use 1520 instead of 1500, unless you are using an AR636 in which case 1500 is correct./QUOTE]
That probably explains why I always end up putting in a little offset when I connect to the receiver. Thanks Andy! You learn somethin' new every day!
