You really have no idea what you are talking about. The gyro doesn't fly the plane. It assists in stability... It takes the twitch out of the plane.
If if you fly jets, you would understand. Jets do not fly like prop airplanes... They are much more susceptible to turbulence at lower speeds than most aerobatic planes.
You can not feel a properly setup gyro system setup.
BTW: gyros were used for several years at the TOC. You know what happened? The guys that won before gyros, were the same that won with them.... And when they took them away... Still they are guys that won. Gyros don't fix bad geometry, or you missing rolling points, or snaps or help the plane roll, nor do they fix your wings level, wind correct, nor do they fix radius changes or matching.
