RCU Forums - View Single Post - Tamiya Flash Unit fail
Old 02-15-2015 | 06:25 AM
mcovalsk
Originally Posted by ausf
I made a few flash units, they're just xenon strobes with a Cap and a trigger coil. The real problem is sourcing shielded wire. The voltage from the cap is so high that it'll arc through normal insulation.
Few years ago I had to enlarge a sherman the flash, and used a ray cathode tube cable from an old TV, but had to change completely as the joint will make an arc.
