Here are some pictures of the on going modifications , I dropped the batt. down to the underside of the fuselage
and moved it forward against the fire wall, it was a great improvement on the CG. But I added weigh again to the tail
with the construction of a batt. box and a access door. According to Eflite the motor i have installed is good for up to
6-7 lbs, so it looks like lead weights will be added to the nose.
