RCU Forums - View Single Post - Gremlin Help
Thread: Gremlin Help
Old 02-17-2015 | 07:04 AM
  #51
Propworn's Avatar
Propworn
Originally Posted by Tbobflow
I'm interested in how you build the engine mount into the foam wing Propworm. Can you show some detail pics?
This is what makes this wing so easy and simple. It fully symetrical so you cut each half from foam then full sheet them individually including a root plate and tip plate. Then glue them together and use 4 inch wide .75 oz glass for the middle top and without having to wrap it around the leading or trailing edge. The wing comes to a point where the motor mount is to go. Build the motor mount and tank mount as one unit then cut out the opening to fit in the wing. Glue in place and your done. This will be explained in the build topic ok?
Dennis
